Oil recommendation
Old 02-21-2008, 08:03 PM
sntemp's Avatar
Default Oil recommendation
I've got a 2002 A6 3.0 with 72K miles. I will be getting it back after some extensive repairs and was thinking since I put so much money into repairs maybe I should get some input on what type oil I should start using.
What do you all recommend?
Old 02-21-2008, 08:41 PM
Kevin's Avatar
Default RE: Oil recommendation
You want an oil that is VW 502 00 compliant. Audi has a TSB that identifies all 14 of the oils that comply with this standard. It is almost unbelievable that Audi only certfies 14 oils as being satisfactory. Some of themost common of the 14 oils include: Mobil 1, Pennzoil Platinum European Formula Ultra, Quaker State European Engine Ultra, Kendall GT-1 Full Synthetic Motor Oil and Castrol SLX Professional OE. I guess you could also call your dealer and see what they suggest.
Old 02-21-2008, 10:07 PM
tombigbee's Avatar
I use Castrol Full Synthetic.
Old 02-21-2008, 11:28 PM
hey51515's Avatar
I have an a6 02 3.0 as-well. At first I went full synthetic. But it is really not needed. So I have been doing half syn half Mobil 1.
Old 02-22-2008, 01:27 AM
joetm's Avatar
i have a 02 2.7t and i have been using regular non synth.... is this bad ... is this why my car smells like burning when i push it really hard it smells like the turbos are cooking!
Old 02-22-2008, 11:03 AM
esandes's Avatar
Banned
mobil 1 0W-40. it's all i use. i would use the 5w-40 mobil 1 but it is hard to find. both are approved by the manufacturer.
Old 02-22-2008, 04:38 PM
Costner's Avatar
I use 5W-30 Mobil 1 because I can find it anywhere. I buy the 5 qt jugs from Wal-Mart and they run about $21. On a non-turbo car a full synthetic probably isn't a huge deal, but for those of you with turbos *ahem* joetm *ahem* I would highly recommend you use a full synthetic as it performs much better in high heat situations (and a turbo is a high heat situation).
ALso, I run at least 5,000 miles between changes, and I am not afraid to go as high as 7,500. When you balance out the increased price of the oil vs. a conventional and you factor in the longer intervals between changes....the cost difference is essentially negligible.
My local Ford dealer will take my filter ($4 at fleetfilter.com)and oil and change it for $10, so for me it's a no brainer. Sure I could do it myself, but my time is worth more than $10, and they vacuum the interior, top off the fluids, and even do the windows.
Old 02-22-2008, 05:33 PM
ppgoal's Avatar
2.7T - 0W-40 in the winter and 5W-30 in the summer. I can only find the 0W in quarts at Autozone but I buy the 5-quart 5W at Walmart. I also go about 8k between oil changes.
Old 02-22-2008, 07:23 PM
beefski's Avatar
i use castrol syntec (full synthetic) in 5w-40 and it also meets the vw specs. it will say it on the back of the bottle.
make sure you use a good filter, mann is the preferred one for audi
eelpie
08-27-2014 05:59 PM
mblayton
02-01-2012 10:31 AM
idfnl
09-11-2010 06:52 PM
Bantanic
04-14-2006 07:49 PM
BFlan
02-17-2005 12:47 AM
Quick Reply: Oil recommendation
