xenon lights flickering
Old 01-18-2008, 10:21 PM
OOOOA4's Avatar
Default xenon lights flickering
The xenon lights on my 2006 A4 will flicker every once in a while, weather on a smooth or bumpy road surface. It was barely noticable at first. Tonite it was very pronounced to the point where an oncoming driver flashed his high beams at me.
Any sugestions as to why this may be happening ?
AmI in for a big repair bill? My car is about to turn 50,000 miles.
Kevin
Old 01-18-2008, 10:42 PM
Bondga's Avatar
Default RE: xenon lights flickering
are they HID's? if they are the ballast are probably overheating. if there just xenon bulbs i would guess there is a short...
Old 01-18-2008, 10:47 PM
OOOOA4's Avatar
Thanks for the info. I will mention your suggestions when I bring my car to the dealer this Tuesday.
Old 01-19-2008, 12:49 AM
tdn's Avatar
tdn
tdn is offline
ORIGINAL: Bondga
That's a bit confusing. HID = Xenon, they're both the same. Xenon being the gas used by HID (High Intensity Discharge), which is the technology.
If you're still under warranty, just bring it to the dealer. If you're out of warranty, first try making sure all connections are secure, if they are and the problem persists, replace both bulbs, otherwise the colors won't match. HID's change color as they age. This is a common problem and one of the two usually fixes it for most people. If you're out of warranty, be sure to do this on your own, otherwise expect to pay too much for a simple job.
By the way, this info is for OEM HID's.. if you've got after market, you can try this too.. but it can be another problem (ex: ballasts). I have the same problem and did a lot of searching (something the original poster should have done) and what I wrote above seems to be the solution for most people with stock HIDs that flicker.
Old 01-19-2008, 01:04 AM
pimphell's Avatar
My expirence with HID lights is that they all will flicker at one point or another, new or old. Both of my cars will do this. I just installed an HID 8000k kit on my black one recently and it does it sometimes. My red one does it once and a while also and those came stock with HID
Old 01-19-2008, 01:07 AM
veloracer's Avatar
Get the light issue checked out before you hit 50k. As long as you're still under warranty, it'll be free.
Old 01-19-2008, 07:30 AM
CLX's Avatar
CLX
CLX is offline
Zombie Defense Force
ORIGINAL: tdn
ORIGINAL: Bondga
Xenon doesn't always mean HID. You can get ricer 'xenon' bulbs at Pep Boiz and get the HID experience without actually getting HID lights.
Old 01-19-2008, 09:40 AM
sineo's Avatar
ORIGINAL: CLX
You don't mean that, right?
Old 01-19-2008, 09:45 AM
CLX's Avatar
CLX
CLX is offline
ORIGINAL: sineo
ORIGINAL: CLX
Well, they are xenon filled bulbs, and since the glass is blue tinted you can get the HID experience if you aim them high enough to blind people or just drive with your high-beams on.
I was just making the point that you can get xenon filled bulbs that aren't HID's to tdn.
Old 01-19-2008, 09:52 AM
sineo's Avatar
ORIGINAL: CLX
ORIGINAL: sineo
ORIGINAL: CLX
Well, but those bulbs you're talking about aren't xenon bulbs...they're "xenon look". They're still halogen. Definitely not the HID experience .
Quick Reply: xenon lights flickering
