service light on dash
Old 12-08-2007, 08:57 PM
Dudek12's Avatar
Default service light on dash
Just had a ? I have an 03 a4 1.8t and on the dash there is a service light going on when i start the car nothing happens just comes on then off it has been coming up for two weeks well 1st it said 14 days till service 3000 miles and 13 days and so on till yesterday when it said service. Anyone else have this befor thanks
Old 12-08-2007, 09:06 PM
littleflavio's Avatar
Default RE: service light on dash
that means u need to have ur car service. if u had someone do the service other than the delaership its still gana come out, u need to have that reset with audi dealership if u did had ur serice somewhere else. mine does that like right now. before i did reset it myself i just forgot the procedure, i will post it if i find it on the net.
Old 12-08-2007, 09:08 PM
Service light reset procedures
Articles > General car diagnostic information
The following Service Light Reset Procedures are published here as described by technicians working on these cars. We have not tested these procedures and cannot accept any responsibility for damage/costs incurred resulting from their use.
[align=center]Service Light Reset Tools[/align]
If you can't find your car listed below, check out our range of Service Light Reset tools
WARNING: Resetting your service light is not a remedy for servicing your vehicle. Only perform these procedures after an oil change/vehicle service and obey your manufacturer's suggested service intervals.
Procedures are available for the following manufacturers/models:
Manufacturer
Years
Models
Audi
All
A4 and A6
BMW
2001 onwards
All
Ford
All
Galaxy
Vauxhall
1999 onwards
All
Volkswagen
See models
With digital odometer
Volvo
1998-2001
S / V / C70 Models
S80 Models (1998)
S80 Models (1999-2000)
XC 70 Models (2001)
Audi A4 & A6 (All years)
[ul][*]Turn off the ignition[*]Press and hold the button on the left side of the display while turning the ignition on[*]Service OIL will be displayed[*]Pull out the button on the right side of the display until the service prompt is cleared[*]The display should now read --- [/ul]
If the above procedure does not work, outlined below is an alternative procedure:
[ul][*]With the ignition off, push the right button[*]Turn the ignition on and then pull the left button[*]This should clear the warning message [/ul]
Old 12-09-2007, 08:07 AM
chaos92287's Avatar
it means go get your oil changed. then afterwards you reset the service reminder using the procedure littleflavio posted
Old 12-09-2007, 05:50 PM
Dudek12's Avatar
Ya i just changed the oil like 1000 miles ago ill just use those instructions above to shut it off thanks
Old 12-09-2007, 06:11 PM
auditech79's Avatar
You have a B6 A4 so you have to do the same procedure as the two buttons except you have to push and hold the button that looks like a small wrench, then turn on the key and hit the 00 button to re-set the reminder.
smoovmusicdj
08-25-2008 08:15 AM
pschmid
06-23-2008 06:47 PM
bradsmits
12-20-2006 10:32 AM
El Supremo
09-11-2004 02:41 PM
Quick Reply: service light on dash
