10 airbag codes!?!
Old 12-07-2007, 04:07 PM
bennyc767's Avatar
Default 10 airbag codes!?!
Ok, just got done scanning my car because the airbag light was on, and came up with ten codes:
01219 Rear airbag igniter (Dr Side)
01220
01213
00656 Seat occupied sensor (P Side)
01215
01216
00591 Seat belt switch (Left)
00592
01228
01578 Airbag Deactivation warning lamp (P side)
So i cleared the codes, and all but the last one came back on within about one second. What do you guys/girls think about that? Alot of these are resistance and open circut "intermittent" codes, why would they come back so soon? Should i look at replacing the airbag ECU, or trying to track down every single code there? Can anybody shine some light on the ones that aren't described (i'm using shareware version of VAGCOM). Any help would be greatly appreciated as this is the last dash light i need to get rid of!
Ben
Old 12-08-2007, 11:25 PM
Default RE: 10 airbag codes!?!
has the car ever been wrecked? more that anything you have a bad control mod. I've seen that alot. also ck' for corrosion at the connector for the control mod. if corroded replace mod. and clean the connector. if your car is newer than 00' you need to have the mod. matched with the imob. and the dealer i think is the only one able to get the key codes for the imob. I worked for audi and vw back in 2001-2003.
Old 12-10-2007, 09:44 AM
bennyc767's Avatar
the car has never been wrecked. the car is a 2000 US A4... I thought the US market cars didn't have immobilizers. by control mod do you mean the airbag ECU behind the HVAC controls?
Old 12-10-2007, 10:09 AM
nordska's Avatar
the airbag light is on in my 01 A4 as well. what did you use to read the code? obviously my obdii reader isnt going to work...
Old 12-10-2007, 03:17 PM
bennyc767's Avatar
ORIGINAL: nordska
you need vag-com or a VAG tool designed to do read the other control modules in the car. I use a $15 ebay cable, VAGCOM 409-1, and my laptop, works great!
Old 12-11-2007, 10:29 AM
nordska's Avatar
thanks for the info, i am going to look for one on ebay!!
tenstringer009
01-01-2014 11:03 PM
markymarc
02-20-2013 12:03 PM
vtraudt
03-03-2012 08:26 PM
vtraudt
12-16-2010 04:48 PM
Cubanator
03-19-2008 01:22 PM
Quick Reply: 10 airbag codes!?!
