CEL - Pulled Code P3081
RE: CEL - Pulled Code P3081
19537 4C51; P3081[/b] - Engine temperature too low
Check for a missing thermostat, a stuck thermostat, or a cooling system that's all antifreeze. You might need to replace your coolant sensor also ($10)
Hope that helps!
Hope that helps!
ORIGINAL: munkee
Is this an OEM part or can I pick it up from AutoZone?
AUUUUUTOOOOO ZONE! (commercial voice sound)
...they don't call it a "stealership" for no reason...
Dealership=[sm=lildevil.gif] AutoZone=[sm=grinangel.gif]
Goodluck Bro!
it seems to be a code with many meanings and asked on many sites so ill look into it,
http://forums.vwvortex.com/zerothread?id=1506656
http://forums.vwvortex.com/zerothread?id=2570430
edit:
Sample Answer below :
VW Jetta GLI/VR6, 2003
The error code, "P3081" has been identified from a recent diagnostic and I was wondering if you could be so kind as to help me interpret what this code is and how, perhaps, to remedy this problem..if any...
"19537 4C51 P3081 Engine temperature too low"
That DTC is indicative of a missing thermostat, a stuck open thermostat, or a cooling system with 100% antifreeze. It is NOT associated with a defective ECT G62.
[align=left]
[blockquote]
When the coolant temperature is too low, that does not necessarily mean a sensor failure. Sounds like the sensor is telling you the truth.
Watch the temperature on the scan tool as the engine warms up. Look for things that keep it from warming up. Things like radiator fans on all the time, straight anti-freeze, stuck open thermostat and so on. That is what it means. It means a system problem, not necessarily a component failure.
http://www.freeautomechanic.com/checkenginelight.html[/blockquote][/align][/align]
edit:
[align=left]
[blockquote]
