TRANSMISSION DIPSTICK
Old 02-03-2005, 09:44 PM
Brich's Avatar
Default TRANSMISSION DIPSTICK
ON A 97 QUANTRA A4, WHERE IS THE TRANNY DIPSTICK. I CAN'T FIND IT, IS THERE ONE?
Old 02-03-2005, 09:58 PM
Jestnomen's Avatar
6th Gear
Default RE: TRANSMISSION DIPSTICK
no such thing. Audi says the tranny fluid is a "lifetime fill".
Old 02-04-2005, 12:47 AM
flyboy's Avatar
Not even on Auto?
Old 02-04-2005, 01:59 AM
david9999's Avatar
Even on a "Quantra".
You may be a noob, but first at least make the effort to learn your car's name.
The Auto transmission is a"lifetime fill".
What means that you don't change it until your transmission breaks.
Of course, your transmission will break sooner if you don't change the transmission fluid.
The transmission fluid has to be checked from underneath the car, with the car perfectly level, and the transmission fluid warmed up slightly. Generally I leave this to a local garage that specializes in Audis.
While you are at it, you may want to change a few quarts of transmission fluid, the fluids from the center differential and rear differential. Bleed the brakes. get a turkey baster and swap out the power steering fluid. Use new Pentosin 11 fluid only. Top up the battery with distilled water, drain your radiator and re-fill with new VW pink antifreeze and distilled water.
Your car will thank you.
wdills
05-12-2015 08:30 PM
Don_Korcari
05-14-2010 12:52 PM
ambig1.8t
12-26-2008 01:13 AM
SouthernAudi
10-11-2007 07:13 AM
1staudi
12-02-2003 04:27 PM
Quick Reply: TRANSMISSION DIPSTICK
