2.7T intake?
Old 01-31-2007, 10:51 PM
NJ@BoroKidA6's Avatar
Default 2.7T intake?
I need some help decided what intake i should buy. The decision is between the Evo MS cold air intake for the 2.7t, and the AWE S-Flow. Also, with the cold air intake, what are the chances it will suffer from heatsoak? thanks...
Old 01-31-2007, 11:44 PM
2k S4's Avatar
Default RE: 2.7T intake?
S-flow, it goes in the stock airbox. The EVO intake pulls in hot engine air, since it does not have a heat shield.
Old 02-01-2007, 12:47 AM
DevilS4's Avatar
2nd here, not as flashy looking or loud but actually makes power instead of loosing it.
Old 02-01-2007, 06:05 AM
TommyL's Avatar
all show, no go = no no
Old 02-03-2007, 01:29 PM
Hey, thanks for all your help, but im still stuck on the Evolution MS cold air intake...2ks4, you said it doesnt come with a heat shield, yet on the website it says the intake does come with aluminum heatshields. Would these heat shields prevent the intake from sucking in hot air?
Old 02-03-2007, 01:50 PM
2k S4's Avatar
ORIGINAL: NJ@BoroKidA6
If that is what YOU want, then purchase it.
From what I know the EVO intake doesn't have a heat shield, they might have thrown one in, & I have no nothing about it.
Old 04-30-2007, 10:40 PM
onefasts4's Avatar
bought both off an auction on ebay from some guy doing some crazy custom intake. The EVOMS does have a heat shield and a rain shield not to mention is LOUD on the boost. The only thing that bugs me is that the heat shield goes into the stock airbox grommets so it isnt bolted in or anything which makes it kind of flimsy.
Old 05-01-2007, 03:16 AM
blackmagics4's Avatar
The first generation EVO intake has a heat shield. . . but the setup isn't perfect, when you try to take your filter off to clean it you will see that it fets smashed when trying to take it out.... I have the evo kit, and other than cleaning it, I like it.
Old 05-21-2007, 01:50 PM
slvr_S4's Avatar
so the s-flo is the best???....have you heard of the ABD racing intake?? is it any good...i know it says somtihng about not street legal but how the hell would the cops know??
Old 05-21-2007, 02:21 PM
Joeski's Avatar
Listen to 2K S4. Go with the S FLo. The engine compartment of these cars really hold a lot of heat. The heat shields of these cold air intakes are useless. You will suffer from heat soak and you will lose performance with a open air/cold air intake.
OOOO
Quick Reply: 2.7T intake?
