Rubbing noise from steering wheel
Old 08-21-2006, 06:46 PM
a4mad's Avatar
Default Rubbing noise from steering wheel
Hi,
I've recently noticed a rubbing noise coming from the steering wheel. Doesn't sound like anything to serious but is very annoying. Sounds like plastic rubbing somewhere near the top of the column. also getting a creaking noise when I turn the wheel slowly. However, this only lasts for about 10 degress in each direction.
Anybody got any ideas on this?
Regards
Old 08-21-2006, 07:34 PM
CRAZYHAWK's Avatar
Default RE: Rubbing noise from steering wheel
Spray some white lithium grease where the rubber parts meet. This is in the interior , into the steering column.
Old 08-21-2006, 08:08 PM
quattrosedan's Avatar
Maybe you are hearing your power steering pump, check your ps fluid level.
Old 08-21-2006, 08:17 PM
check all the above but concentrate on where the noise is emanating from ( is it the height adjustable steering wheel ) does it need checking
Old 08-21-2006, 09:03 PM
IDTrav's Avatar
same problem i had a few weeks back...like ^ said spray some grease around the bushings, fixed mine! I took it into the shop they said was play in the tierod end that was making the noise.
Dallas09
07-29-2008 02:13 AM
a4mad
11-16-2006 11:20 AM
dragondesigns
09-29-2006 08:43 PM
anita
02-02-2005 02:57 AM
Quick Reply: Rubbing noise from steering wheel
