can clogged fuel filter cause a car to run rich?
Old 06-28-2006, 03:16 PM
rnbguy's Avatar
Default can clogged fuel filter cause a car to run rich?
hmmm?
Old 06-28-2006, 03:18 PM
onepoint8tee's Avatar
Default RE: can clogged fuel filter cause a car to run rich?
Maybe lean but not rich.
Old 06-28-2006, 04:33 PM
^^^ precisely
Old 06-28-2006, 06:19 PM
wood_e's Avatar
If its clogged your car may not be getting good fuel pressure, this will cause the car to run lean. If you are indeed running rich your fuel pressure may be higher than normal. I suggest that you check the pressure.
Old 06-28-2006, 06:24 PM
a bad maf would make you run rich also a bad o2 sensor or bad timing
Old 06-29-2006, 12:49 AM
LarryInPA's Avatar
Check your air filter, too. The computer will prevent a clogged air filter from creating a rich fuel condition, but performance will be restricted.
Old 06-29-2006, 10:00 AM
david9999's Avatar
Run a vagcom and pull the codes.
Could be anything from bad oxygen sensor, leaky fuel injectors, MAF, fouled plugs, very dirty air filter, etc.
How do you know you are running rich?
Old 06-29-2006, 04:14 PM
acetrebo's Avatar
bump,
rich condition should generate codes. Why do you think its running rich? What codes are you getting?
Old 06-29-2006, 04:24 PM
im for that, wow no avevor makes me wonder if I already answered this get your fingers out otherwise ill put my own back on
[IMG]local://upfiles/12092/CD6D86C2383A4E8B85DB1EBFEB06D035.jpg[/IMG]
Old 06-29-2006, 04:28 PM
its back till you get a better one
Quick Reply: can clogged fuel filter cause a car to run rich?
