Shocks and Struts, BUMP, RATTLE!!
Old 05-07-2006, 02:51 AM
ewaardo's Avatar
Default Shocks and Struts, BUMP, RATTLE!!
I once posted here asking the forum for any advice on the fact that since I bought my 2001 Audi A4 1.8quattro every time I go over a speed bump with the front tires, as I'm coming down, it feels as if my shocks (or springs) bottom out and I hear this loud bump like if they hit right underneath my hood. I took it to a dude specialized in european cars (audi, bmw, mercedez, etc) and he said thats just how audis are built and that I just need to be more careful on how I go over bumps. I'm a little confused cus you should at least be able to go over a damn speed bump the regular way everybody else does. Does anybody have any ideas on what to do? Will taking it to the stealership be a waste of time. Im only at 45k miles.
My car also makes a rattleling noise whenever I turn it on and it stays on for like 4 seconds then it just goes away....Any ideas on what it might be? It kinda sounds like when somebody rolls their "R" with their tounge. I hear the little tiny rattle everytime I shift as well...I really want to fix this problem cus other than that the car runs like a champ.
thanks
Old 05-07-2006, 03:14 AM
Sp33d07's Avatar
Default RE: Shocks and Struts, BUMP, RATTLE!!
dude until you are 100 percent sure dont believe what the dealer tells you, i went to a dealer cherryhill audi in nj they left my brake pad loose and it made that rattle sound, when i took it back they said it was from suspension went to a dealer in pa it was my from brakes double check and make sure unless the car hit a curb of sumthin hard
Old 05-07-2006, 03:28 PM
onepoint8tee's Avatar
Could be Strut bearing(s) and the noise at start up is probably your secondary air injection pump... Mine and others do the same thing.. Any other rattles could be a heat shield, exhaust rattle, check your front engine mount (snub mount) housing to make sure it is tight and also that the stock mount hasnt deteriorated.
czum09
11-27-2011 02:46 PM
johnnyv8
07-30-2011 07:40 PM
A4udi205
12-14-2007 09:43 AM
Black_97 A4
06-22-2007 12:59 AM
Q_AUDI
04-11-2006 12:28 PM
Quick Reply: Shocks and Struts, BUMP, RATTLE!!
