Beeping and brake light flashing on dashboard...
Old 10-05-2004, 11:13 AM
skibum0019's Avatar
Default Beeping and brake light flashing on dashboard...
Hey guys,
In the past few days, this has happened two or three times:
I'm driving (doesn't matter if it's the highway or a side street), and all of the sudden, the "ABS" light and the "Brake" (which usually only comes on when I use the parking brake) light on the dashboard (right in the spedometer) start flashing and there's a beeping sound. Then, after about a second, it stops, and everything seems fine. Has anyone run into this before, or know what it is, cause I don't have a freakin clue, but if it has to do with the brakes not working properly, then it's something I should probably pay attention to, no??
thanks!!!
Old 10-05-2004, 12:47 PM
audihere's Avatar
Banned
Default RE: Beeping and brake light flashing on dashboard...
my guess is u need to change ur front pads bc they electronic sensors in them when they get low. so id check that out.
Old 10-05-2004, 01:38 PM
Jestnomen's Avatar
6th Gear
Do you have a VAG to see which specific code is throwing your lights?
Could be an ABS wheel speed sensor.
Could be a bad ABS module
KEYAZ
05-27-2016 06:30 AM
cipi888
07-16-2013 05:11 PM
sushidub
10-06-2010 12:38 AM
Quick Reply: Beeping and brake light flashing on dashboard...
