Removing front ABS speed sensors
Old 02-23-2006, 11:11 AM
PaulA4's Avatar
Default Removing front ABS speed sensors
Tell me if i'm being stupid here guys but how do the front wheel speed sensors for the ABS come out?
It's a 1998 2.8 A6, I've just stared blankly at them for ages.
Old 02-27-2006, 12:04 PM
PaulA4's Avatar
Default RE: Removing front ABS speed sensors
nobody know at all?
Old 02-27-2006, 12:14 PM
in most cases it is stuck solid and will be damaged on removal its a 1 bolt job, if fitting a new one then just use a screw driver and pry it out
Old 02-27-2006, 02:21 PM
dan908's Avatar
The newer ones are a little bolt/ screw, but I think you might still be on the old style. Anyway, look at it and see if there is a little bolt and remove it if there is. Then, what I use is a pair of vice grips and a cloth to not damage the heck out of it. Clamp tightly. Twist gently side to side and don't damage the wire or the head. It should just slide out but sometimes Audi cannot even get um out with out destroying them. THey told me that, but the vice grips method worked. You should clean them and then wipe them off with an oily rag (not soak them down, just get a little slip to it.) They are supposed to be cleaned frequently.
Old 02-27-2006, 02:25 PM
if its shot why worrying about getting it out
Old 02-27-2006, 02:28 PM
dan908's Avatar
True, my own that was bad I beat the crap out of it getting it out with the vicegrips it was kind of the test sensor, after that i started using the rag to protect the head. But if he just wants to clean them :-)
Old 02-28-2006, 10:25 AM
PaulA4's Avatar
cheers i'll give that a try, yeah i just want to try cleaning them first before i shell out the cash to replace the things.
reynoldso4
Audi Q7
08-19-2013 10:31 AM
GTwinkie
09-25-2010 05:51 PM
makav3li
03-18-2010 09:13 PM
pepsicolla
05-13-2008 11:00 AM
hyland
05-19-2007 10:04 AM
Quick Reply: Removing front ABS speed sensors
