Possible Limp Mode - engine dies in gear
Old 10-04-2013, 06:52 PM
Melchizedek's Avatar
Default Possible Limp Mode - engine dies in gear
1998 A6 2.8 Quattro, 180K miles, automatic
The engine light is on. It will start up (as long as the battery has juice - as it sits in the driveway it slowly loses juice and needs a jump). When I put it in D or R it will move but as soon as I hit the gas and it goes over 1000 rpm it dies on me. When in P or N it will rev up just fine.
I've replaced the crank shaft sensor. I've done a TB reset (i was throwing TB codes at one point, but then they left; it appears they're back again).
I've done a battery reset (disconnect and touch the two ends together for 20 seconds).
History:
I bought the car in April and it was running "fine" but had some codes and lights so I started fixing things. Then at one point it wouldn't stay running unless the rpm were above 1100. So I changed out the MAF. Now it won't stay running above 1000 rpm (exact opposite problem).
Here are my codes (I "bolded" what I think is applicable):
Friday,04,October,2013,14:22:14:48882
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Mileage: 290540km-180533mi Repair Order:
Chassis Type: 4B - Audi A6 C5 (1998 > 2006)
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Mileage: 290540km/180533miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D01
Coding: 06252
Shop #: WSC 02325
VCID: 6CD9C0041C35057E58B-4B18
6 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17967 - Throttle Body (J338)
P1559 - 35-00 - Fault in basic settings
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 -
17953 - Throttle Valve Controller
P1545 - 35-10 - Malfunction - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
16538 - Oxygen (Lambda) Sensor B2 S1
P0154 - 35-10 - No Activity - Intermittent
Readiness: 0010 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 F
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
VCID: 2A55061CD641DB4EEA7-4B32
2 Faults Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C39D0C48C1535FE68B-515A
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 G
Component: A6-Klimavollautomat D55
Coding: 00160
Shop #: WSC 02324
VCID: 1E3DDACC9A0927EE86F-25AA
20 Faults Found:
00797 - Sunlight Photo Sensor (G107)
31-10 - Open or Short to Ground - Intermittent
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
00779 - Outside Air Temp Sensor (G17)
00756 - Left Vent Temp Sensor (G150)
00757 - Right Vent Temp Sensor (G151)
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-10 - Blocked or No Voltage - Intermittent
00710 - Defroster Flap Positioning Motor (V107)
01810 - Actuating Motor for Temperature Flap; Right (V159)
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
29-10 - Short to Ground - Intermittent
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01297 - Sensor for Vent Temperature; Footwell (G192)
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
01582 - Signal for Coolant Temperature
Address 15: Airbags Labels: 4B0-959-655-AI7.lbl
Part No: 4B0 959 655 K
Component: Airbag 7 Audi 0501
Coding: 00206
Shop #: WSC 02324
VCID: 38712C5418ED79DE6C3-515A
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 930 RX
Component: C5-KOMBIINSTR. VDO D15
Coding: 07262
Shop #: WSC 26008
VCID: 8F233788CDE31E669D9-513C
4 Faults Found:
01039 - Coolant Temperature Sensor (G2)
00667 - Ambient Temperature Signal
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 C
Component: Central Lock/Alarm D30
Coding: 15885
Shop #: WSC 02325
VCID: 2957F910D347D056E3D-4F3A
9 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00668 - Supply Voltage Terminal 30
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 A
Component: Sitzmemory D05
VCID: 2B5B0318D9BBC246111-4B18
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
VCID: E0C1243460FDD11E743-4B4A
4 Faults Found:
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00006
Shop #: WSC 02325
VCID: E5CF35207FDFB436875-5178
End ---------------------------------------------------------------------
Can you help me?!
Old 10-26-2013, 08:58 PM
Sold the car. No need to respond.
No I did not get it fixed.
T.A.T.E. Customs
09-23-2014 08:51 PM
ioncehadanaudiandidontlikeitatall
09-18-2014 10:40 AM
locod64
08-20-2011 12:00 PM
ldesha1
04-17-2011 04:23 PM
ml_audia6
11-24-2008 06:39 PM
Quick Reply: Possible Limp Mode - engine dies in gear
