Windsheild washer fluid leak!!
Old 09-07-2012, 08:04 PM
quattrojoe's Avatar
Default Windsheild washer fluid leak!!
Has this happened to anyone before? the coolant leaked all over the garage floor on the driver side front. I cant see anything visible that is leaking under the hood. Its an 04 2.7t with 100,000 miles on it
Old 09-07-2012, 08:20 PM
z28pete's Avatar
The container may have split, or one of the hoses came lose or broke.
Old 09-07-2012, 09:16 PM
eejimm's Avatar
^^^ Fairly common problem - check the hoses, pumps, connectors, everything on the reservoir that could leak. There are two outlets on the tank - the upper one is for the headlamp washers, the bottom one is for the windshield. If the tank only drained halfway down then the leak is in the upper one. Try filling the tank with water and looking at the connections, etc with a bright flashlight to see where it's dripping.
There are also some connectors in the hoses themselves, like the one inside the bumper for the headlamp washer line. Any of them could be leaking.
Jim
Old 09-10-2012, 07:31 PM
hxgaser's Avatar
Is it the coolant or the windshield washer fluid?
Old 09-11-2012, 01:02 AM
smtguy's Avatar
Maybe windshield washer fluid. I had mine replaced at the dealer and it still leaked. I finally gave up, and just kept filling it with water.
Davidiot
04-16-2015 11:37 AM
mcanedo92588
07-01-2013 11:27 PM
ckbkny
08-28-2009 04:04 PM
ckbkny
03-15-2009 07:40 PM
benzodiazepine
02-24-2009 12:27 AM
Quick Reply: Windsheild washer fluid leak!!
