P0171 System Too Lean (bank 1)
Old 05-06-2012, 11:29 PM
BesI's Avatar
Default P0171 System Too Lean (bank 1)
While driving today i get a cel so i stoped at the autozone to scan it and see what up with that so i get P0171 System Too Lean (bank 1) car runs fine no problems. I checked tho hose to see any crack but i dont see anything. Any advise where should i start? also i did do research on this.
Old 05-06-2012, 11:47 PM
ImTheDevil's Avatar
Most likely a MAF, primary O2 sensor, or vacuum leak issue.
Old 05-07-2012, 01:43 PM
BesI's Avatar
when its MAF or O2 sensor it does not show which one is it?
I did check it again reset the Cel Light but still came up.
Old 06-08-2012, 02:02 AM
long arm's Avatar
I'm having the exact same issue on my 02 1.8tqm. Runs fine, new PCV, new fuel filter. No detectable vac leaks and no change when I disconnected the MAF and took it for a run.
It idles flawlessly and doesn't seem to be down any power at all.
I'm lost.
Old 06-08-2012, 10:39 AM
Emilgevor's Avatar
you can welcome another P0171 member here.
had 2 codes so I replaced PRV and now only P0171 is left. I have no boost gauge yet so cant see if its vac or maf or o2
car seem to run ok for now but I feel that its somewhat underpowered and gas milage could be better.
Old 06-08-2012, 11:58 AM
pa4ul's Avatar
have u looked at the check valves. Alot of times those get corrided letting out interminting leaks. I think there is 5 or 6 on the 1.8 Should be a diagram floating around this site.
Old 06-08-2012, 12:10 PM
Emilgevor's Avatar
i glanced around and found nothing corroded. My engine is pretty clean to be honest for 60k
Old 08-20-2012, 06:52 PM
vic_13's Avatar
you ever figure out what it was? I'm having the same issue
Old 08-20-2012, 08:50 PM
BesI's Avatar
Yes i did, i was getting air in the system from the maf, my intake silicone had pop out which was causing the problem. i did a vacuum test and found air coming in.
Do check all your vacuum lines vic_13 just to make sure is not that and then check maf and o2 sensor
Old 08-27-2012, 03:02 AM
vic_13's Avatar
how would one go about doing a vacuum check
Gordon Gekko
05-29-2013 11:50 PM
boostin_A4
02-24-2010 02:17 PM
MatDHan
12-14-2008 09:36 AM
Tsumik
09-19-2007 11:22 PM
01A4T
11-30-2006 02:01 AM
Quick Reply: P0171 System Too Lean (bank 1)
