Trunk Light and License Plate Lights Not Working
Old 02-22-2012, 11:34 AM
LoriV's Avatar
Default Trunk Light and License Plate Lights Not Working
I recently acquired a 2002 Audi A4 Quattro, the trunk lights and the license plate lights do not work, the trunk open indicator stays on all the time as well (not sure if this is supposed to be the license plate light indicator?) I/we have replaced the bulds, looked for corosion and contact - no power to the license plate lights with the tester. Checked fuses. Checked for pinched wire in trunk. Any suggestions would be greatly appreciated.
Old 02-23-2012, 11:13 AM
M5S5's Avatar
Tech Certified
After checking all fuses i would check the wires that go from the trunk too the vehicles body. They will wear out with opening & closing of trunk after a period of time.
Old 02-24-2012, 08:14 AM
LoriV's Avatar
Default Trunk Light & License Plate Lights Not Working
I was wrong about the trunk lights, they work when the trunk is closed only. Changed the bulbs once again on the license plate lights and still nothing. My trunk open indicator is on when the trunk is closed and off when it is open. So confused!!
Old 02-24-2012, 08:28 AM
M5S5's Avatar
Tech Certified
Sooooooo , did you check the wires?
Old 02-25-2012, 10:15 AM
LoriV's Avatar
Default Wires
Yes, we had initially checked them, then again pulled the inside cover of the trunk lid off, followed all the wiring looking for bare or worn wires. I did read somewhere later that night that there is also wiring under the rubber, I will look there this morning.
Old 05-04-2012, 02:02 AM
Audi_A420's Avatar
Unhappy same issue
I am exerienceing the same problem, all the tail lights work fine besides the liecense plate lights, i replaced them, checked the wires all the way to the body no corrosion or anything, nothing is getting pinched and i still cant get them to work. fuses are fine. i looked threw my manual and it said its most likely a faulty wire... BUT WHERE DO THE WIRES GO after the trunk lid?????
i keep getting pulled over for no lights on my plates!
Prizmatik
08-20-2013 06:06 PM
Pbcrazy
09-06-2012 05:06 PM
Audi_A420
05-06-2012 12:22 AM
exequiel3k
09-13-2009 05:47 PM
Quick Reply: Trunk Light and License Plate Lights Not Working
