vibration under load
Old 09-28-2011, 06:53 PM
Rolling Blackout's Avatar
Default vibration under load
I have this vibration that is most noticeable during acceleration or going up hill (& sometimes while coasting). I replaced both front cv axles due to torn inner boots, but the vibration is still there. I looked at the rear axles but they look ok. What else could it be?
Old 09-28-2011, 06:58 PM
BTW, I replaced the front axles at different times (4 months apart) the left front fixed the vibration for the 4 months so I replaced the right front when the vibration returned. Could the new right front axle be bad?
Old 09-28-2011, 09:14 PM
Dan1969's Avatar
It's a high possibility if the vibration came back after putting the new one on.
Old 09-28-2011, 11:03 PM
thanks, I think I'll try to get a new axle...
Old 10-10-2011, 11:44 AM
So I installed another axle in the passenger side but still have the vibration. Is there a bearing or something on the drive shaft (propeller shaft?) That could be bad?
Old 10-13-2011, 04:14 PM
James94's Avatar
I swear i have the same exact problem. Mine occurs once i hit 3000 rpm. Once its near it my gas pedal vibrates and its soo annoying.
kamchuan
12-06-2013 08:32 AM
liambo1
10-30-2011 05:46 AM
jdahlen24
06-29-2011 02:09 AM
oettinger1919
01-08-2009 08:56 PM
adz
09-12-2006 02:13 AM
Quick Reply: vibration under load
