Effects of bad temperature sensors?
Old 05-23-2011, 05:29 AM
Lornnn's Avatar
Default Effects of bad temperature sensors?
first, my coolant temperature sensor is erratic.. sometimes it'll work just fine, sometimes it'll just sit at cold no mater what kind of driving i'm doing.
second is the outside temperature sensor which has been dangling and moving around inside the bumper since i bought the car. depending on its mood it'll read fairly accurately or just make up numbers
my question is, as the title asks, what are some of the effects of these dodgy sensors? reduced performance? overcompensation? or even more grim effects that i'm not aware of? there is no CEL present
either way i'll be fixing both but id like to be informed.
Old 05-23-2011, 07:11 AM
ImTheDevil's Avatar
The only potential bad effect of the ambient air temp sensor is, if it reads below a certain temp, it'll turn on your mirror defoggers (if your car has them). Too much time with them on burns the fluid inside and turns your mirror glass brown. As for the CTS, it can give you difficulty starting, poor fuel mileage, rough running, and other similar issues.
Old 05-23-2011, 11:47 PM
Lornnn's Avatar
man.. you sure know a shitload about these B5's.. thank you
my drivers side mirror is actually brown around the edges - as i bought it. i just figured it was some cheap replacement where the reflective material was coming off. makes a lot of sense considering that the ambient air sensor has been sitting and jumping around at the bottom of the radiator for who knows how long.
a lot of smaller issues are also explained with the bad CTS. on occasion itll have trouble starting, the mileage isn't all that bad but i spend more time working on it than driving it, and the idle is still rough despite my efforts replacing the vacuum system, spark plugs, seafoam, intake cleaning, MAF cleaned and/or unplugged, +
we'll see how the replacement CTS changes things if at all
Old 05-24-2011, 08:11 AM
ImTheDevil's Avatar
You can just ziptie the ambient temp sensor up out of the way and you'll have way less damage and much more consistent readings, if it wasn't already broken. As for the CTS, a lot of your issues have been shared by other car's and have been solved with a new CTS in the past.
Old 05-24-2011, 07:35 PM
vgo's Avatar
vgo
vgo is offline
im glad i stumbled in this thread...my coolant temp has been doing the same thing. At first I thought it could be the thermostat, but im starting to lean more to the ECT...
Old 05-24-2011, 07:46 PM
ObnoxiousDrunk's Avatar
Still need to change mine as well.
Old 05-24-2011, 11:09 PM
jokeabus's Avatar
Yeah, don't go cheap on that one. Figured I might save a couple bucks and buy a cheaper no name at Autozone, but the POS only worked reliably for a week or two before crapping out. One more thing on my list!
Old 05-25-2011, 04:47 AM
Lornnn's Avatar
which CTS is it? green, blue or black? i'm out of the country now and would like to have it shipped before i get back
Old 05-25-2011, 06:45 AM
ImTheDevil's Avatar
Depends on your car - best breakdown I can give you is that in general the early 12v cars had the black sensor, the 30v and 1.8T dbc cars (98-99) used blue, and the later dbw (post facelift) are green. I'm sure there's overlap though but if you order from ECS, PureMS, or GermanAutoParts, you should be able to have them look up the right one based on your VIN number.
Old 05-30-2011, 08:13 PM
tdepirro's Avatar
I have only just noticed a similar problem with my Temperature gauge. I have a 2001 1.8 quattro, Where does this coolant temperature sensor reside?
Quick Reply: Effects of bad temperature sensors?
