Is driving with a bad ABS sensor damaging to brake system?
Old 01-09-2011, 11:33 PM
normal's Avatar
Default Is driving with a bad ABS sensor damaging to brake system?
I have a bad front ABS sensor. This creates a weird noise/vibration in the brakes when doing slowly and applying the brakes.
Can anyone tell me what is actually happening to make this noise/vibration and whether it is harmful to continue to drive with the bad sensor?
I would prefer to wait for spring to replace the sensor.
Old 01-10-2011, 12:11 AM
vgo's Avatar
vgo
vgo is offline
you can pull the fuse for the ABS. Someone will have to chime in to tell you what and where the fuse/relay is or pm 'hiwords'.
I dont think that will get rid of your noise/vibration problem. Could be something else.
Old 01-10-2011, 12:12 AM
Aud1A4's Avatar
i dont think the sensor is the problem. i think your rotator might be warped which is causing the vibration
Old 01-10-2011, 02:45 AM
MetalMan's Avatar
Moderator
I drove around like that for a little while, and my brakes still work after getting everything fixed up. Though I wish I had just pulled the ABS fuse as vgo suggested, would have gotten rid of the weird feel/noise.
Old 01-10-2011, 02:59 PM
Dallas09's Avatar
It isnt harmful to drive with a bad sensor, but you might notice the car steers when you step on the brakes and you will not stop as quickly.. so it is best to pull the abs fuse (you can look it up in your owners manual, im not sure what it is), it is located where all of the other fuses are on behind the driver door jam or whatever its called.
The sound you are hearing is the abs hydraulic pump turning on (the hum), and the pulsing feel and sound is caused by valves rapidly opening and closing in the abs pump. The pump creates the same force as you pumping on the brakes, and the valves are to control what wheels receive brake pressure (similar to someone pumping the brakes, except more precise and rapid). ( http://auto.howstuffworks.com/auto-p...lock-brake.htm ) Pulling the fuse is your best option until you fix it, but you should remember that when you press the brakes hard enough, they will act as they would in an older car. They will lock up and be disproportional and cause you to fish tail and prevent you from steering if the wheels lock up since there is no abs control any longer. Pulling the abs fuse will also cause a flashing brake light and solid abs light on your dash.
By the way when you say noise and vibration, if you mean the entire car and not just the brake pedal vibrates, you have a problem with the regular brake system. And if noise you mean a screech or loud rubbing sound of some kind it also is not the abs system but rather the regular brake system. This would be something to be concerned about and is not fault of the abs system.
bobbyenglish61
08-27-2013 07:55 AM
kreiter
01-18-2012 10:36 PM
Audi B5
12-08-2007 11:45 AM
lkruvant
09-17-2007 11:10 PM
Quick Reply: Is driving with a bad ABS sensor damaging to brake system?
