2003 A4 Wiper blade replacement/conversion
Old 12-13-2010, 07:18 PM
denaliman's Avatar
Default 2003 A4 Wiper blade replacement/conversion
My wife's 2003 Audi A4 quattro needs new wipers. They seem to be the older style (early April 2003 build). Is there a Bosch blade that will directly fit these such as the ICON? or is there a conversion kit I can get to upgrade the blades to the newer style? What would be required?
THX.
Old 12-13-2010, 10:15 PM
ilackav8's Avatar
oddly enough ive been looking at this a lot recently as i need some new blades. according to boschs site, the dont make ICONS for the a4's (our year anyway...) but they make regular replacements. ecs tuning has a conversion for the newer style (b7) wipers on their website ( http://www.ecstuning.com/Audi-B6_A4-.../Wiper/ES6574/ ).
i dont know if thats all you need for it,but theres a starting point anyway. most of the parts places i go to dont stock the size needed for the 2003 a4, but will order them for you if you want. the dealers always have them in stock and are usually only slightly marked up.
btw the bosch part # is 3 397 001 909 as per their part finder
Old 12-14-2010, 11:58 AM
pa4ul's Avatar
I upgraded to the aero wipers and talk about night and day difference. Probably one of the best things ive done to my car. Installing the first one took a little bit of time but there is a trick to it and the once i found out thesecond one took me all of 2 minutes to swap.
Old 12-14-2010, 12:03 PM
ilackav8's Avatar
is the quality of the wipers better or is it a life expectancy improvement with them? or both?? im about to be on my second set of wipers in a little over 2 years...they just keep tearing
Old 12-14-2010, 01:09 PM
shane.trammell's Avatar
better life and better quality. You gotta do the swap. You need arms and blades from a b7.
Old 12-14-2010, 02:36 PM
ilackav8's Avatar
good to know. is the conversion from ecs all that you need? ive been thinking about doing this for quite a while
Old 12-14-2010, 04:13 PM
Looks like that is all you need. I bought 4 parts: 2 arms, and 2 blades.
Old 12-14-2010, 04:43 PM
denaliman's Avatar
Thanks I will look into the swap. I bought replacement blades in the meantime. They were shredded due to the current ice storm here.
Old 12-14-2010, 04:52 PM
denaliman's Avatar
Do I need any new nut/bolt for the wipers or can I reuse the existing ones?
Old 12-14-2010, 05:18 PM
I had a friend put mine in and only those 4 parts had to be replaced. everything else was re-used
Quick Reply: 2003 A4 Wiper blade replacement/conversion
