Removing rear deck speakers
Old 09-12-2010, 08:46 PM
BT5150's Avatar
Default Removing rear deck speakers
One of my rear deck "subs" is sounding awful, it actually sounds like something is rattling around in the speaker cone when the bass hits (which I hope is the case because that would be an easy fix!) How do you get at removing the rear deck speakers, I can't figure out how to get at them?
Old 09-12-2010, 10:28 PM
ImTheDevil's Avatar
Fold down the back seat, remove the side bolsters, unplug the third brake light from inside the trunk, then pop the forward edge of the deck upward to unclip the snaps that anchor it. Pull it forward and you can slide it out to reach the speakers. It's probably the center cap of the cone banging around. A little super glue will reanchor it.
Old 09-12-2010, 11:02 PM
Tourbo24's Avatar
i had the same problem with the center cap. it was cracked so i used super glue to fix it but its doing it again, i guess superglue isnt the best thing possible to use on the center cap. any ideas of what i should use next time to fix that crack on the center cap?
Old 09-13-2010, 11:25 AM
twoeightquattro's Avatar
use rubber cement, it will hold it firm, but will still allow flexibility so that it will be able to vibrate without getting loose again., i'd recommend taking of the cover, cleaning around it and applying rubber cement all the way around.
Old 09-13-2010, 01:30 PM
colony777's Avatar
also, you dont have to remove the side bolsters. i never did anyway. if yours is a 1999.5+ you have 3 seat anchors on the deck as well. plastic covers pop off, bolts revealed
Old 09-13-2010, 03:06 PM
Msnickbroderick's Avatar
Actual WIZARD
Why not replace? I bought some 30$ pioneers at walmart one night and they are great for the factory radio.
Old 09-13-2010, 06:18 PM
meloman's Avatar
Old 04-11-2011, 11:21 PM
maddimcknight's Avatar
hey, i have a 99 audi a4, i can't get the third brake light to unplug, am i doing something wrong?
does it just snap off or clip off or what!
thanks
Old 04-12-2011, 12:37 AM
scottrod's Avatar
i replaced mine with these
http://www.amazon.com/Infinity-Refer...2582979&sr=8-2
perfect fit no modding required, sounds great with the +3 built in bass boost
compliments my kicker l5 sub really good
Dillonmmm@gmail.com
03-11-2009 09:48 AM
AmadiAudiA4
08-15-2008 11:31 PM
ggoodling
09-03-2007 03:55 PM
xerexb
08-17-2007 01:28 PM
Crowley
08-28-2006 09:35 AM
Quick Reply: Removing rear deck speakers
