2005 4.2 parking brake stuck
Old 07-23-2010, 08:02 PM
hoffmanas's Avatar
Default 2005 4.2 parking brake stuck
Parking brake is stuck on and wont release. Is there any way to manually override it? Help!!
Old 07-24-2010, 06:56 AM
Kevin's Avatar
Old 07-24-2010, 09:55 AM
hoffmanas's Avatar
Kevin,
Thanks .. tried it it still did not not release the EPB so far i ave tried the TSB you provided disconnecting the battery and praying .. none have fruited the desired result.
Old 07-24-2010, 12:35 PM
hoffmanas's Avatar
Got it to release... the problem is apparently a loose connection at the rear right caliper..
Old 06-18-2021, 02:07 PM
Dur453's Avatar
Default Emergency brake light
Emergency brake light is flashing and alarming. Parking brake does not light up when switched on or off. Car does go into gear. What could be the problem?
Rickardc
08-17-2014 10:29 PM
Hareth
05-13-2014 02:25 PM
bugginout420
08-04-2011 10:23 AM
hoffmanas
07-23-2010 08:01 PM
jakej
11-12-2008 08:55 PM
Quick Reply: 2005 4.2 parking brake stuck
