PO241 Diagnostic Code
Old 07-22-2010, 03:48 PM
psanta's Avatar
Default PO241 Diagnostic Code
My 2002 A4 3.0 currently has 121,000 miles and has had the check engine light on for at least 2 years with the PO241 code (Bank 1 Catalyst warm-up efficiency below threshold). I have read several posts here about it and it seems that the catalytic converter is bad and needs to be replaced. This is very expensive as you know. This seems to be a very common issue among the 3.0 engines. Has anyone attempted to get Audi to replace one free of charge by complaining to the regional office? Seems they should do something if so many are failing. Mine failed shortly after I hit 80,000 miles (when the emissions warranty expired) so I am really ticked-off about this.
Could the problem be anything but the catalytic converter (e.g. O2 sensor)?
Old 08-04-2010, 03:06 PM
arman123's Avatar
P0241 code I'm sure is for the boost sensor were did you get the code from search fir this code online and always says boost sensor Or sometimes called thrust sensor is your car underpower if it is check the boost sensor I think it on the intetcooler pipe it has two philip screws pull it out and check if it got oil on it if so give it a clean with brake cleaner
Old 08-05-2010, 05:31 PM
psanta's Avatar
Default Correction
yeah, sorry, I put the wrong code up. The correct one is PO421.
and b
09-15-2013 12:48 PM
mjw14
03-07-2011 06:56 PM
pbrules10
11-25-2010 02:27 PM
k5gixxer
03-06-2007 06:44 PM
Quick Reply: PO241 Diagnostic Code
