A4 2.8 quatro water pump replacement
Old 07-18-2010, 04:26 PM
tbenach's Avatar
Default A4 2.8 quatro water pump replacement
Can anyone help me locate a thread that shows pictures and step by step on how to do this. I bought the kit for the timing belt with the water pump and belt tensioner on it 2 years ago and the pump and belt tensioner both are bad.
I saw the guy do the job without taking the front end off but I am kind of stuck on removing the fan bolts without pulling the radiatior.
Thanks,
Old 07-18-2010, 04:42 PM
onepoint8tee's Avatar
It's pretty simple to get the bumper cover off and slide the front end out enough to get in there comfortably (not having to completely remove it.) A 2.8 timing belt writeup should have all the info you need.
Old 07-13-2011, 09:46 AM
sdg's Avatar
sdg
sdg is offline
Default A4 1.8 waterpump
Hi. I discoverde that my audi 1.8 1996 waterpump needs repacement - leaking water and weird sound. Can someone please explain how i would go by doing this replacement - I am handy but cannot afford the pro's.
thanx
sdg
Old 07-13-2011, 10:28 AM
ImTheDevil's Avatar
Plenty of DIYs for the whole job on a 1.8T out there. They'll be the same for a 2.8 until you get to removal of accessories and timing gear. Most of that is evident when you're looking at it. On either car the timing belt blocks the water pump partially or fully ^^^so the whole thing has to come off before the pump comes out - it's the last part to remove before reassembling the whole thing.
Old 07-13-2011, 06:10 PM
IanWPB's Avatar
I just watched the JHMotorsports 2.7-8 timing belt video.. It's great. I definately recommend it. Watch the clip JH Motorsports Inc.
It goes over taking out the waterpump.
Like ImTheDevil said the Timing belt is in the way of the waterpump. It would probably be easier to just redo everything. You may as well go grab a new timing belt while you're in there.
Old 07-14-2011, 11:14 AM
DOC_DEPALMA's Avatar
I would definitely recommend doing the timing belt too, like they said ^.
Old 07-14-2011, 11:44 AM
ImTheDevil's Avatar
To clarify, not just the belt - get a timing kit from one of the vendors and do all the associated parts. Eventually they have to be done anyhow ^^^so don't make yourself duplicate the labor later on. Do it now and drive securely.
keld3000
09-30-2010 02:03 PM
spindrift
09-22-2009 11:16 PM
pazo
B8 Models
05-15-2009 08:00 AM
siders83
03-18-2007 02:56 PM
gmeyer
08-09-2006 03:58 AM
Quick Reply: A4 2.8 quatro water pump replacement
