Fuel pump going bad??
Old 06-21-2010, 05:44 AM
2003 audi a4's Avatar
Default Fuel pump going bad??
I have a 2003 1.8t with 90,000 and my fuel pump started making a humming noise now it is almost all the time even when its sitting and running :/ can you diy?? Or what should I do???
Old 06-21-2010, 09:52 AM
shane.trammell's Avatar
I did it myself. Do you have experience working on cars? This one can be tough.
here is the diy http://www.a4mods.com/index.php?page.../fuelpump.html
Couple of pointers, when twisting the pump to remove it the hammer method did not work for me. I wrestled with it for a while then used the handles of channel locks placed in the pump to twist it and it worked perfectly. Secondly, when putting the pump back in it can only go one way and it should drop right in.
Old 06-21-2010, 10:53 AM
Mike-2ptzero's Avatar
The fuel pump will do that when the fuel filter starts to get clogged. If you haven't changed the fuel filter yet you might want to do that before replacing the pump.
Old 06-21-2010, 11:58 AM
Thanks for the help ill check everything out
Old 06-21-2010, 12:44 PM
VitaminB6's Avatar
If the problem does turn out to be your fuel pump, this would be a good time for an upgrade :-)
See https://www.audiforums.com/forum/sho...5&postcount=14
skihigh2299
10-11-2015 05:54 PM
skihigh2299
09-25-2015 12:09 AM
jsethwerner225
11-14-2014 01:55 PM
DJmart
08-03-2013 11:08 AM
Luisthehomie
10-01-2012 05:24 PM
Quick Reply: Fuel pump going bad??
