OBD can't connect, 2001 TT
Old 06-05-2010, 12:47 PM
lajos's Avatar
Default OBD can't connect, 2001 TT
Hello,
I have a 2001 Audi TT Quattro. For some reason the OBD reader cannot connect to the car, so no pass on emission test
Here's some information and stuff I tried:
- the car has the original BOSE radio working, and station info is displayed on the dashboard
- engine check light is not on, and I can run the diagnostics from the dashboard, which prints OK at the end
- I checked all the fuses on the side panel
- I cleaned the OBD connector with contact cleaner
- tried 3 different OBD readers (emission test computer, handheld OBD reader at shop, and I have a simple OBD reader), they all error out
- I checked the K-line voltage between pins 4+7, reads 0.18 volts
- I do not have a VAG-COM
- the car was not driven for over a year (due to new babies in the house), the battery was dead so I replaced it
What else can I do to diagnose/fix this problem? I've seen some posts suggesting cleaning radio/HVAC connections.
A mechanic suggested that some cars need to go through certain number of startup/warmup cycles before the OBD works, not sure if that applies.
Should I get a VAG-COM?
Thanks so much,
-lajos
Old 08-03-2010, 10:19 AM
yavuzongul's Avatar
i have same problem, too. im thinking its about wiring... but i dunno how can i check it..
Old 08-30-2010, 09:13 PM
dtex's Avatar
Did either of you have luck with this issue? I have having the exact same problem/symptoms.
Old 08-31-2010, 09:33 AM
lajos's Avatar
I still have no solution. I got a vag-com, which can't connect to the car either.
Old 09-01-2010, 07:28 AM
yavuzongul's Avatar
i found problem maybe your problem is same, too..
i had a superchips on my car and i cannot connect to car with superchips..
now i changed my eprom and put different one, now i can connect in a second
im sooo happy... do u have something like this on car ?
Old 09-02-2010, 09:47 AM
lajos's Avatar
Well, I'm not the first owner of the car, so it's possibility. Although this car has passed inspection since I got it (they need to connect to obd for smog), so I'm afraid I have a different issue.
But I'll check for superchip. Thanks for the tip!
Old 04-01-2012, 06:50 PM
Tilts-a4's Avatar
I assume by now you have resolved this issue or sold your vehicle :-) What did you find out.
Old 04-02-2012, 09:56 AM
dtex's Avatar
Check your wiring on the OBD connector. I believe I had a wire/pin that was loose in the connector. You might want to use a continuity tester/wand for this.
Old 10-19-2016, 05:24 PM
Erol Kalkan's Avatar
Does anybody find a solution for no link issue with the OBD II?
Old 12-07-2016, 01:14 PM
npcullen's Avatar
Old thread, but looking for help.
Wife's 2002 TT dies on road, and will crank, won't fire. I get there 20-30 minutes later, everything checks out, no obvious defects, she cranks it starts right away. we're three miles from home, drives home, and it dies on our lane. I grab my OBD tool, won't connect. about 20-30 minutes go by, and it connects, shows a P0322 code, and starts and we drive it to the house, I backed it into the garage and pull it onto a set of ramps.
Any idea if this is common? There is a relay that feeds the ECM, can it cause this issue. I am an old Cat mechanic, I have a preconceived notion that the power supply being cut to the ECM can throw an errant code, particularly speed/timing sensors.
Dr Pooface
07-09-2015 07:33 PM
Kenny Gerard
08-16-2013 02:49 AM
Expplucky
05-22-2013 06:31 AM
a4audia4
11-06-2010 12:57 AM
ast03
11-22-2009 12:35 AM
Quick Reply: OBD can't connect, 2001 TT
