Valve Cover Gasket causing idling issues?
Old 05-24-2010, 02:25 PM
audiblacky's Avatar
Default Valve Cover Gasket causing idling issues?
Hi all,
I have been trying to tackle this ongoing issue. Rough idle with RPMs jumping to 1200 in park. P0507 :Idle Control System Higher than Expected and P0171 :Fuel Trim,Bank1 System too Lean. Checked all lines and hoses.
1) Air escaping from PCV - replaced this item and there was oil in the old one. Car runs better but CEL comes back with rough idle.
2) Clean MAF - Issue still there.
3) Now I have oil on ground!? 2-inch round diameter. Previous owner mentioned that the valve cover gasket needs to be replaced. I have just been holding it off.
Can a faulty valve cover gasket be causing all these issues? I went ahead and ordered the gasket and will be spending by sat replacing this. It better work.
Old 05-26-2010, 08:50 AM
02A4kid's Avatar
idk but i just did the valve cover gasket in my 02 a4 1.8T this morning, now previously my car sounded like a deisel and i was watching the oil drop off from the gasket straight onto the cat and now that ive replaced it it sounds a lot quieter but my problems still persist....but i dont think that your issues are coming from the valve cover gasket. my engine also starts out around 1200 rpm and after a minute or so slowly crawls back down to 800 so idk how to interpret that at the moment..
Old 05-26-2010, 05:29 PM
R.A.I. Motorsport's Avatar
Former Sponsor
Valve cover won't really cause idling issues unless its a massive leak. First I would check for vacuum leaks. Then I would check the plugs/coilpacks/MAF/02 sensor.
Old 05-27-2010, 12:49 PM
audiblacky's Avatar
Thanks guys. Any luck 02A4? Having the same problems. Start up car, idles at 1200 then when I put it in drive goes down to 800.
I'll still replace the valve cover gasket to at least stop the oil but I think my issue will still be there. After this and checking the lines again for leaks, I might have to head over to a mechanic, don't want to spend my 3-day weekend working on my car...
Old 06-01-2010, 03:34 PM
audiblacky's Avatar
Update: Replaced Valve Cover Gasket (stupid small hose to the left added about an hour to this project, couldn't remove the cover as easily as I thought).
Oil drip is fixed, high RPM is still there at idle aahhh.
Removed MAF cable and car is running the same so the MAF is not the issue.
Im pretty sure its a leak somewhere. Off to my buddy's shop to see if he can help/locate leak.
Old 06-09-2010, 12:46 AM
audiblacky's Avatar
It was a crack in the breather hose behind intake (crank case vent system). Talked to dealer and they say they replace that everyday on audis. They wanted $1300 to replace it because they needed to heat the hoses together or some bs, went somewhere else for a fraction of cost.
Problem fixed and codes gone, ...for now.
Chris2525
08-26-2014 08:05 PM
cekren
07-22-2014 01:06 AM
robert.jones
12-10-2008 08:01 AM
robert.jones
12-10-2008 07:56 AM
nero117amx
07-16-2007 01:57 PM
Quick Reply: Valve Cover Gasket causing idling issues?
