Brake Pad worn warning light
Old 04-19-2010, 02:17 PM
sonali_des's Avatar
Default Brake Pad worn warning light
Hi,
I have got a 2002 Audi A6 Quatro. The yellow brake light (O) started flashing a couple of days back. Now the car is not accelerating properly. I need to push the gas pedal a lot to move at 45-50 MPH. I have new front pads and rotors installed a few months back.
Any ideas on what could be the issue? Thanks in advance for the help.
Old 04-19-2010, 11:28 PM
makav3li's Avatar
yeaa the wiring that connects to the sensor is probly corroded and destroyed...mine was destroyed pretty bad, but all it is, is 2 wires that connect to the brake pad sensor, its very obvious when u remove the front 2 wheels (only the fronts have them) and the wire will probly just be hanging there. You can either reroute the wires back into the sensors or short the 2 wires together and the light will go away, i went for the shorting of the wires...was alot easier and i can usually tell when my pads are low just from driving.
Your accelerating problem is not brake pad related, do you have a CEL (check engine light)? if so or even if not, take it down to autozone and get it scanned real quick to see if any codes pop out, or even better borrow or buy a vag-com
Old 04-20-2010, 11:12 AM
sonali_des's Avatar
Thanks for the valuable inputs!
CEL is not on! The accelerator problem is happening after the Brade Pad Warning Light started coming.
Thanks,
Old 04-20-2010, 01:30 PM
NH_USA's Avatar
The only way the acceleration problem and pad sensor would be connected is if the new brakes were incorrectly installed and the front brakes were dragging. BUT you would have felt that long before the light came on.
You gotta figure out if the pad light is due to worn pads, bad connectors, or broken wires. If it is worn pads someone did a poor job or your riding around with a foot on the gas and the other on the brake.
pbrules10
03-26-2011 01:17 AM
06AFOUR
B7 Models
05-11-2010 09:25 AM
sonali_des
04-19-2010 10:02 AM
SilverA6SLine99
03-01-2010 05:45 PM
tsr4509
03-15-2007 04:12 AM
Quick Reply: Brake Pad worn warning light
