Replaced Serpentine Belt now wont start
Old 04-08-2010, 10:42 AM
bcan's Avatar
Default Replaced Serpentine Belt now wont start
Hey guys: Thanks in advance!!
So today we finished up replacing my serpentine belt in my 97 1.8 quattro.. After everything's back together it wont start.
When the belt broke half of it was wrapped around the crankshaft and the other half was still on the pulleys but it was twisted, It was all removed but I wasn't sure if maybe there was some sensor or some special instructions on putting the serpentine or any of the other accessory belts back on?? I dont know how long it was driven like this since it was driving fine and it was only when i slow down to turn into a parking spot did it seize up..
It does turn over and the motor seems to be spinning the belts nicely.. Also wont start with jumpers
Any suggestions are welcome!! THANKS!
Old 04-08-2010, 10:50 AM
dragonrage's Avatar
Is it being turned by the starter only or is it sort of "almost" starting but failing or what? Try feathering the gas pedal? Try some starting fluid? Maybe the belt broke some wires and/or vacuum hoses when it snapped?
Old 04-08-2010, 11:04 AM
bcan's Avatar
Thanks guys, problem is the car is 20 minutes away so I have to check these things later when we can get back down there. But please, any other suggestions welcomed! And I'll keep you updated
Old 04-08-2010, 11:55 AM
hiwords's Avatar
well what does it do when you tried to start it? you have to give us more info so we can narrow down the problem. otherwise we can give you a huge list of things to check and you would be there all day versus the 20 min drive
Old 04-08-2010, 12:08 PM
bcan's Avatar
Its barely not starting and there doesn't appear to be any damage to hoses... Could the timing belt breaking cause the serpentine belt to break... Just unsure of why the serpentine broke in the first place..
Old 04-08-2010, 12:16 PM
hiwords's Avatar
well did your T belt break at all? the serpentine belt was either old or not put on right when it was replaced to have it break.
Old 04-08-2010, 12:17 PM
chocalotstarfish's Avatar
Super Moderator
If the TB broke you would know. Broke TB=bent valves=goodluck!
SmoothTT
10-18-2009 09:49 AM
Rudyu
09-02-2009 10:23 AM
shinto99
08-11-2009 11:09 PM
shady927
06-20-2008 01:29 AM
Bryceaudi
02-18-2006 10:10 PM
Quick Reply: Replaced Serpentine Belt now wont start
