Oil Change intervals?
Old 03-30-2010, 09:47 AM
Lance Kragenbrink's Avatar
Default Oil Change intervals?
Sorry guys if its here, I looked and could not come up with the answer using the search function. So ill ask.
What type oil, and how often and what type filter. Id like to do this the right way and not cut corners.
2001 A6 2.8L
Thanks so much!
Old 03-30-2010, 09:51 AM
makav3li's Avatar
5-40 synthetic with the correct oil filter...any autozone/walmart will point you in the correct direction for the filter.
Old 03-30-2010, 10:53 AM
Badger Bud's Avatar
Mobil1 0-40W, Mann Oil Filter, 4,000-5,000 interval.
Old 03-30-2010, 01:10 PM
NH_USA's Avatar
Least expensive name brand 10-40 oil I can find - Mann filter only - every 10 K miles
I drive 100 miles a day so the moisture is driven out of the oil.
If you drive less, you should stick to the 4-5K interval.
If you do only short drives you should change it every 2-3 K miles
Before the **** Audi guys begin, I'll tell you that I got over 350K out of an 89 200QT before giving up due to numerous problems - none oil or motor related - and have over 240K on my 97 A6 that uses a quart in 5K miles - In fact -when it needs the second quart I change the oil instead of adding more.
The general rule is that people either change their oil too soon and waste money or forget to change it all together.
Old 03-30-2010, 01:42 PM
jhuffman's Avatar
I haven't heard of mann oil filters, but I have been using wix for a few years and I like them. RockAuto.com has all your tune up stuff if your not the go out and shop kind of guy
Old 03-30-2010, 09:28 PM
hxgaser's Avatar
Also depends on weather, type of driving, and what type of oil was used in the past...
But without getting complicated, my choice is 5W-40 synthetic. about 4K between changes. Some people find that a little excessive but I am meticulous, aka ****.
Stay away from Fram filters. Use Mann, Wix or reputable brands.
Old 03-31-2010, 07:03 AM
Kevin's Avatar
I get my oil changed at the dealer every 5,000 miles.
Old 03-31-2010, 03:47 PM
NH_USA's Avatar
At the dealer!!!??? Are you rich or something??
Old 03-31-2010, 04:03 PM
nemohm's Avatar
No kidding!
Old 04-01-2010, 06:33 AM
Kevin's Avatar
I am an original owner with gray hair. I will let you decide the rest.
Quick Reply: Oil Change intervals?
