Heated Seat Retrofit
Old 12-14-2009, 02:29 AM
CycloSteve's Avatar
Default Heated Seat Retrofit
Quick question...If I do not have the Winter Package in my 98.5 A4 2.8 which has the power leather seats, would those seats have the heating elements? No, the dash does not have the switches either.
I ask, as other manufacturers often install the elements in all seats, and all you need to do is add the switches in some cases, or switches plus a partial harness from a donor vehicle.
Definitely want the heated seats, and hoping that it might be easier than tearing into them and adding an aftermarket set of heaters.
Old 12-14-2009, 09:34 AM
dragonrage's Avatar
Not sure, but look for the wires coming from the seats.
Old 12-14-2009, 10:51 AM
ImTheDevil's Avatar
I am pretty sure the seats with heaters were not fit without the controls. You'd most likely have to buy heated seats and put them in - I don't think you'll have the heating elements.
Old 01-28-2010, 12:14 AM
CycloSteve's Avatar
Currently retrofitting a hybrid of OEM switches with aftermarket elements. Will post details once finished.
Old 01-28-2010, 12:30 AM
vgo's Avatar
vgo
vgo is offline
Old 01-29-2010, 12:24 AM
CycloSteve's Avatar
Originally Posted by vgo
Definitely one of the threads that I have followed.
The only issue that I have found with that thread is that their wiring diagram/key of the connectors does not correspond with the actual pin numbers on the connectors, and only notes one of the two seat-end plugs. I am working up the actual pin-outs based on the EWD, and will post that with my write-up. This will help for those retrofitting with both the OEM elements, or the heatedseatkits.com ones.
Cheers,
Steve
Old 01-29-2010, 03:55 PM
ImTheDevil's Avatar
That is one hell of a comprehensive DIY procedure!
team illuminata
11-10-2011 01:10 PM
rollyfoster
07-26-2007 02:50 PM
AndyA4C
10-15-2006 06:55 AM
jza80
12-09-2005 02:35 PM
Quick Reply: Heated Seat Retrofit
