Cleaning Mass Air Flow Sensor
Old 09-21-2009, 04:23 PM
copper07's Avatar
Default Cleaning Mass Air Flow Sensor
98 A6 1998 Quattro - 145k
I was told I was need to replace the mass air flow sensor for $300 insatlled. I would like to clean it first and see if that fixes it. How do I clean the sensor and what cleaner should I use.
Old 09-21-2009, 04:34 PM
hxgaser's Avatar
They actually have a MAF sensor cleaner. You will need a security torx bit, which is a torx bit with a hole in the center to remove the MAF. Just take out the screws and shoot it with the cleaner. Wait for it to dry before you put it back in.
Old 09-21-2009, 04:50 PM
histeel's Avatar
300 is way to high do a little searching online auto parts warehouse has them for 65.00 you have to pay 76.00 additional for a total of 150.00 but you get your 76.00 back when you send them back the core. you can also clean them with rubbing alcohol and a Ziploc bag.
Old 09-21-2009, 08:54 PM
Midniteoyl's Avatar
You can also remove the whole housing and shoot the cleaner into the hole the sensor sits in, if you dont have a security torx.
Old 09-21-2009, 10:46 PM
nm3210's Avatar
I just used a set of locking pliers around the head of each torx screw :-D Also, the MAF Cleaning stuff worked awesome for me! cleared up the codes that were coming up (i think it was system to rich/lean).
Old 09-22-2009, 09:51 AM
NH_USA's Avatar
Check Shokan or Force Five if you need a new or used one.
Or Blauparts for a new one.
$300 is WAAAAAAY to much!
PS consider looking for another mechanic.
Old 09-22-2009, 02:13 PM
copper07's Avatar
I will clean the sensor and see if the car runs better. I will be going to another shop in the future.
Old 09-22-2009, 11:41 PM
Jackmup's Avatar
Have you noticed that Shokan wants like $5 less than a new part for everything. I found a cup holder brand new for 35 delivered and they wanted 45 plus shipping for a used one. A little greedy up there in Woodchuck, NY.
Old 09-23-2009, 08:13 PM
nm3210's Avatar
Was that the cup holder by the shifter????? I could use one of those....
Old 10-07-2009, 04:18 PM
copper07's Avatar
Where can I purchase the cleaner?
Quick Reply: Cleaning Mass Air Flow Sensor
