cigarette lighter outlet not working
Old 05-21-2009, 11:12 AM
lespaul2510's Avatar
Default cigarette lighter outlet not working
I was in my car last night trying to fix a small tear in the seat with one of those leather repair kits. If you've ever used one before, you know that they require a cigarette lighter or iron to heat the little warming tool. Anyway, I began and it seemed like it was working fine. After a few warm-ups, it simply stopped working. I don't know if its because I borrowed the lighter from my Excursion (The lighter was missing when I bought the car) or maybe I just blew a fuse. I tried using a few car chargers but to no avail. Has anybody else had this problem? If so, how did you fix it?
Old 05-21-2009, 12:07 PM
ghost6303's Avatar
its a blown fuse, i dont have my manual in front or me but i think its a 5 or 10amp fuse.
Old 05-21-2009, 12:24 PM
Lindz's Avatar
i had the same trouble and i changed the fuse thinking that would help and it didn't. i might have to pull out the housing and replace the full stocked.
Old 05-21-2009, 02:07 PM
Veegard's Avatar
Measure voltage in fuse holder. Put in a 15amp fuse. Most probably problem solved ;p
Old 05-21-2009, 03:38 PM
redline380's Avatar
Legal Moderator
im guessing that you using the lighter from the excursion blew the fuse because it is most likely rated for a different amperage. that fuse socket is prolly in the door jam fuse panel and it has a display telling which all the fuses are for. find the lighter one. 9/10 if your 12v lighter/accesory socket isnt working its because a fuse is blown.
Old 05-21-2009, 05:54 PM
Where's the fuse box located? It's a 2001 A4 Quattro 2.8L.
Old 05-21-2009, 07:51 PM
never mind, I found it. It looks like the problem is the fuse. I'll pick a few up sometime this week.
Old 05-21-2009, 09:04 PM
vgo's Avatar
vgo
vgo is offline
i think the your horn goes out as well when the cigaretter lighter is out due to a fuse.
Old 05-21-2009, 10:43 PM
hmm... interesting, I'll try that just to make sure
Old 05-21-2009, 10:48 PM
hcaudikeed's Avatar
weird thing for me is my cig lighters dont heat up at all, but both sockets work fine. power my gps perfectly. i tried with both the front and rear cig lighters in both front and rear sockets.
Quick Reply: cigarette lighter outlet not working
