Audi A4 Headlight replacement
Old 04-28-2009, 03:21 PM
That1Chick's Avatar
Question Audi A4 Headlight replacement
Hi. I'm sure this has been posted here with this question, but I am trying to figure out how on earth to change the headlight bulbs in a 2004 A4. I took it to the local auto parts store and they wouldn't even touch ti Any help would be much appreciated.
Old 04-28-2009, 06:00 PM
CRAZYHAWK's Avatar
You'll need a T-30 bit. There are either 3 or 4 screws to remove.
Old 04-28-2009, 10:22 PM
PacCoast's Avatar
You'll need to remove and replace the whole headlight unit. You need to use the T-30 size Torx wrench. There are 4 screws that hold in the headlight, remove the two that are on the top area of the headlight and just loosen the two that are on the lower section, as they can by easily lost/dropped in the engine compartment. Remove the wiring harnesses and carefully pull out the headlight. (make sure to disconnect the battery before removing the headlight) Then just reverse the process with the new headlights!
Old 04-29-2009, 06:37 PM
zippy_gg's Avatar
If you have the V6 engine you will need to remove the air scoop to gain access to some of the screws.
Old 04-29-2009, 08:25 PM
Darkprodo's Avatar
you DONT need to to replace the entire housing for a burnt out bulb
you DONT have to disconnect the battery
the rest is true.
Old 04-30-2009, 11:05 AM
PacCoast's Avatar
the rest is true.
Disconnecting the battery is just a precaution, nothing wrong with that. And yes, it is true that you do not need to replace the entire housing when changing out a burnt bulb...BUT you still need to remove the housing to change out that bulb.
Old 05-04-2009, 07:13 AM
its_sak's Avatar
Question need help
i was able to replace the passenger side by removing the air filter assembly, but the driver's side was a real pain, not much room to work. i got it replaced, but im thinking removing the driver's side headlight might of been way easier. Does anyone have pictures or better details of where the lower screws are?
Old 05-07-2009, 01:33 PM
PacCoast's Avatar
Try this link : http://www.lustload.com/?p=147 is has detailed instructions and pictures.
clewis37
04-13-2014 11:31 PM
oldmots
04-24-2012 05:53 PM
Vishone
06-09-2010 08:11 AM
gerardof71
01-10-2009 08:21 PM
drwoods
07-09-2007 09:10 AM
Quick Reply: Audi A4 Headlight replacement
