90k service.
90k service.
wasup guys i got a 2000 a4 1.8. i jus hit 90k miles and i want to get the service done. what is included in the service and about how much does it cost? im located in fremont ca and was wondering if anybody know of any shops close by that will do it for a good price! thanks for your help
timing belt is the big part of a 90k. not sure what else the manual calls for but it could pretty well be done in your drive way. TB will run about a grand if you have somebody else do it. if that's the case, make sure they install a water pump with a metal impeller while the front end is off. that is generally what causes the trouble.
wait, you said you just hit 90k in a 2000?!?! i have an '01 at 152k.
There are differing opinions as to exactly when, but the timing belt should be done as part of the 80K or 85K (depends on year and original dealer, some cars had an initial 5K mile service) mile service. Do not wait. Replace the water pump, tensioners, rollers, and serp belts while you're at it.
Hmm, seeing you guys gives lot of hope.
Have seen many horror stories in the forum about Audis after
60K miles or so, was having doubts about the reliability of
these cars. Was thinking of selling mine just before the warranty
expires.
May be don't have to :-)
2007 A4 Quattro
expires.
2007 A4 Quattro
