a4 b5 front and rear bumper removal and installation
Old 07-18-2008, 11:31 PM
dbansal's Avatar
Default a4 b5 front and rear bumper removal and installation
hello,
can someone please post a how to on removing and installing the rear and front bumper????
thanks!
Old 07-19-2008, 01:19 AM
ImTheDevil's Avatar
Default RE: a4 b5 front and rear bumper removal and installation
I haven't seen or tried the rear removal, but check the DIY section here or at www.audidiy.com and look up the timing belt procedure - it'll walk you through the front bumper removal (which is very easy).
Old 02-16-2011, 08:56 PM
DANGER6's Avatar
I have been looking for a link like this
Old 02-17-2011, 10:53 AM
Mike-2ptzero's Avatar
Rear comes off pretty much the same way. There are a few bolts in the trunk.
Old 02-17-2011, 11:07 AM
Dozanti's Avatar
what mike said ! When you open the trunk, lift the carpet up like youre going for the spare tire. On each side are two greenish bolts, (4 total) remove them and the bumper will come off. *note* after removing the bolts, you have to push the bumper in and that will allow you two disconnect the bumper cover by the wheel wells, once thats done just simply pull it off
Old 02-17-2011, 11:09 AM
Dozanti's Avatar
Also while you have the rear bumper off, run some weed wacker string or something stiff but thin up the sunroof drains to make sure they are clear since this is the only way to clean the rear drains
Old 02-17-2011, 08:48 PM
NHolzschuh's Avatar
the DIY for cleaning the sunroof drain is actually the best ive seen for removing the rear bumper.lol
Old 05-28-2011, 12:57 PM
absolute 1.8T's Avatar
Exclamation
So I have my bumper off except for the retaining bolt by the fog light... it's rusted to hell and stripped to ****... Does anyone have any suggestions?
Old 05-28-2011, 02:48 PM
Solved... Vice grips with grip like no other... and several, several attempts.
Old 05-15-2013, 01:17 AM
Mhuntington's Avatar
Could you post the link for the DIY clean the sunroof drain? Or anybody find a diagram of where all of the bolts are? I have a 97 b5 and can't for the life of me find the bolts in the trunk to remove the bumper.
Quick Reply: a4 b5 front and rear bumper removal and installation
