Bucking/Jerking on hard acceleration?
I have no check engine light on and no codes coming up. The mechanic replaced the ignition control module. It is still happening. Can it be the coil packs or random misfire without an error code? Any othe ideas? 1997 a4 1.8t
RE: Bucking/Jerking on hard acceleration?
No dead battery.. I just went out and looked around... The tubes connected to the air filter housing are sputtering.. drivers side fan on...passengerside fan is off. My temp gauge never moved above quarter way but now gauge is at half except when I went on highway
hi guys my car is doing the same after just spending $2200 at a dealership....jerking under acceleration, but no codes thrown. Could this be bad plugs?, Just had one coil pack replaced and the others appear to be fine
My mechanic said not plugs or coils without engine light and error code. His online troubleshoot program led him to ignition control module (ecu). That didnt work. He said he also checked for vac leaks?
